Pioneer DVR-220s black screen when record NTSC VHS
Discussion in 'Blu-ray & DVD Players & Recorders' started by mokas, Sep 16, 2004.
  1. mokas
    mokas
    Hi , a month ago when i said i cannot record a VHS NTSC to my Panasonic DVD recorder you say that in fact i need a DVD recorder who can record "false NTSC" ( PAL 60 ) i had to change my DVD recorder ( http://www.avforums.com/forums/showthread.php?t=142779 ) , you advice my to buy Pioneer or Philips so i buy a Pioneer DVR-220s , i test it now and i can record PAL VHS to DVD-RW but when i try a NTSC VHS i have a black screen as result , i know i have to Not mix PAL and NTSC on a DVD-RW so i initialized it before test record a NTSC VHS , i didn't change anything in default setting of the Pioneer DVD recorder , do you know why i have a black screen when i try to record a NTSC VHS ?
    Thank's ;)
  2. mokas
    mokas
    Ok i find solution , i had to change the "Input Line System" :clap:
