I've got a Pioneer DVL-909 LaserDisc/DVD player and I'm having a slight problem with the DVD portion of it. It is very picky about which discs it will play and which it won't. At first I thought the age of the DVD was a factor since this is an older DVD player but I've found that whether it's a brand new DVD or an older one, it will either play it or display "Wrong Region No." and eject the discs. All of my DVDs are Region 1 and I can't find any difference between the ones it plays and the ones it rejects.
Has anyone had a similar issue with this unit and know what I could do to fix it?
Thank you.
Thank you.
