Pioneer DVD dual Burner Choice
Discussion in 'Blu-ray & DVD Players & Recorders' started by barneybelly, Oct 20, 2003.
  1. barneybelly
    barneybelly
    Jan 5, 2002
    183
    I have decided to go for a Pioneer DVD Burner and would like to know if there is a preference between the Pioneer dvr-106 s & Pioneer DVR-A06. I know its a difference of around £25 on ebuyer but was wondering if anyone knows of plus & minuses with either burner??
  2. pd45
    pd45
    The cheaper one is the OEM version - ie the bare bones - you just get the drive to install - the more expensive one will be the retail boxed drive with a disc, manual and (pinnacle) burning software.
    There is no difference in the actual drives. I would say if you are doing a straight swap in your PC with, say, a CD rewriter get the cheaper version.
    Installed one myself just last week - although the Memorex
    1x -RW discs do not work at all. Mirror 2x -RW work fine!!
    Regards
  3. barneybelly
    barneybelly
    Jan 5, 2002
    183
    Thanks for the advice.......just went to order on ebuyer and they have sold out :mad: :mad:
    Looks like DABS for me
  4. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
