Pioneer Dvd 737 Tech Help Needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by MATT JENNER, Dec 21, 2002.
  1. MATT JENNER
    MATT JENNER
    Dec 3, 2000
    396
    22
    Gravesend/Kent
    +18
    I have just had the player enabled to take R1,
    i have noticed when playing region 1 that the prgressive scan blue light doesn't light up on the front of the player, is there a setting i have to activate so that it enables prgressive scan mode ?
    i have it link to my CRT projector via component.
    Any help would be apreciated Merry xmas all
    Matt
  2. Guest
    There is a switch at the back you need to use to set it into Progressive mode.
  3. MATT JENNER
    MATT JENNER
    Dec 3, 2000
    396
    22
    Gravesend/Kent
    +18
    Thanx for quick reply
    I must be a mega thikko here,
    all i have on the back that comes under a switch, is 2 switches
    1 that is TV PAL/NTSC/AUTO - i have it set on Auto
    2 component vid out -525i(480i) / 525p(480p) i have it set on 525i480i
    apart from that there is no other swicthes
  4. Guest
    you need to set that component vid out to 525p(480p)
  5. MATT JENNER
    MATT JENNER
    Dec 3, 2000
    396
    22
    Gravesend/Kent
    +18
    thanx Andy
    i have done that but when i do the picture splits into 2 seperate frames and it look like 2 tv's.
    i assume i need to set my projector up to accept ntsc signals.
    would you agree with this ?
  6. Guest
    I think so, although can CRT units take prog. scan?
