Pioneer DV99 Speaker Grills
Discussion in 'Home Cinema Buying & Building' started by timmorley, Aug 17, 2004.
  1. timmorley
    timmorley
    Jul 17, 2004
    45
    Just trying to gauge a problem with the Pioneer DV99 system.
    Just been on to Pioneer Customer "Service" Centre regarding the problem with
    this DVD systems speaker grille design. They insist that they are unaware of
    any problem with these grilles falling off all the time
    . They say I need to
    return it to the supplier and then they can decide what to do. I said that I
    would be without it for a while then? Yes about a week! Great service then!
    How many people have the same problem?
    TIA
  2. seafoodmix
    seafoodmix
    Nov 13, 2003
    121
    only my centre speaker grill has come forward, but only a little.
    this was discussed in a previous thread , i think jaymac spoke to pioneer too !
  3. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Hi Pioneer told me they were aware of the problem and were looking for a fix . that was a few weeks ago and still no reply.Somebody at pioneer must be talling porkies
    Jaymac
  4. G Canavan
    G Canavan
    Jan 8, 2004
    176
    Jarrow Tyne and Wear
    It's a design flaw so Pioneer are not likely to admit it, it's not enough to put me off the system as in all other areas I was well pleased. I fixed it by using a stronger double sided foam tape from Maplins to hold the grills in place.
  5. timmorley
    timmorley
    Jul 17, 2004
    45
    Did you get a name?
    I'd love to speak to them too!
  6. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Yes but dum dum can't find it. He did say that they would come back to me but didn't specify which year.But like G. Canavan I like it that much a self repair is the answer.
  7. bazlion
    bazlion
    Hi.
    Apart from the Speaker Grill problem, what does everyone think of the overall performance, I see it has SACD, is CD music good?
  8. timmorley
    timmorley
    Jul 17, 2004
    45
    Yes, other than grilles falling away I was suitably impressed with this system. Coming from a home cinema system with a big receiver and floorstanding missions etc. I was expecting a bit of a wimpy sound from it. I soon changed my mind when it was cranked up! Picture quality amazing from dvd. First player I have played with that has proper black levels show up in the THX calibration tests!
    Not tried DVD audio or sacd yet (not buying one just to try it out!)
