pioneer dv99 remote control codes?
Discussion in 'Home Cinema Buying & Building' started by nugetto2003, Jul 20, 2004.
  1. nugetto2003
    nugetto2003
    Does anyone know the pioneer remote control codes for this all-in-one? I want to use tools like total ir but their pioneer codes don't work. I was told that all-in-ones are difficult to program. The dv990 and dv1000 look similar, so maybe the codes work for the nv99.
