pioneer dv717 problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by matmum, Jun 5, 2004.
  1. matmum
    matmum
    Mar 23, 2003
    104
    16
    england
    hi
    i have recently been having some problems viewing some dvds with my pioneer dvd player - i have tested the dvds on other players and they seem to play fine- the errors that have been occuring are blocky segments (in the same place each time) and also freezing. i just wondered if the player can be serviced or some modification added (i.e. a cooling fan) - or trying something simple that might cure the problem.
    also does anyone know what connection i should for my dvd player and television. i have got a loewe acconda and have been reading about component connections (being an improvement scart) at the moment i connect the player with a cinemaquest scart using rgb mode. i am not sure if my dvd player is too old to take advantage of progressive scan, as i think it supports ntsc but not pal, however i havent really got a clue as i am not at all technically minded.
    any suggestions would be greatly appreciated
    cheers :)
  2. jspr
    jspr
    May 11, 2004
    131
    Morpeth
    +10
    I have just upgraded my 717 to a denon 2200. Never had a problem with my 717 but it doesn't have component outputs which you need for progressive scan - that's why I upgraded mine. What sort of display are you feeding the dvd player to ? If its just a bog standard TV that doesn't have component inputs then you won't see much improvement in upgrading your dvd player. The 717 is still a quality player. On the other hand if you have a plasma/proj you will benefit from upgrading to a prog scan model.
    I have noticed a big improvement in both picture and sound quality with the denon - if you do need prog scan and can afford it I would upgrade to a new dvd player.
  3. jspr
    jspr
    May 11, 2004
    131
    Morpeth
    +10
    Sorry - I didn't read your post completely - I see you have a Loewe TV - I don't know whether it has component connections but if it has then I would be tempted to upgrade the dvd player. Perhaps you could demo a prog scan dvd player on a Loewe ?
  4. mjcairney
    mjcairney
    Oct 26, 2003
    6,930
    2
    4
    137
    Airdrie, Scotland
    +877
    I too have a DV-717 and have only twice had the same problems you're experiencing - one was with the Zorro DVD, the other with a copied DVD - the latter didn't bother me as I'm not into copied DVD's anyway - I only tried it once to see if the 717 could handle such disks.
    Apart from that, I have experienced no other problems - the machine has been excellent over the four or five years I have owned it.
    Cheers,
    Martin.
