Pioneer DV656a remote codes
Discussion in 'Blu-ray & DVD Players & Recorders' started by jdanielp, Jul 5, 2003.
  1. jdanielp
    jdanielp
    Jun 20, 2002
    176
    Edinburgh
    +3
    hi there,
    i can't see the functionality on the packaged remote but i was wondering if anyone knows if there are codes to handle the front video on/off and dimmer switches from a learning remote?
    i have a Kameleon so presumably if i knew the codes i could phone them up and get them to update my remote, if such codes actually exist of course. it will be a bit annoying if they don't...
    thanks.
    PS i am sure i read somewhere before that someone was unable to get the Kameleon learning function to work with the 656 remote. mine seemed to work fine however when i set it up...
