Pioneer DV575A - Possible a stupid question on RGB
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dazza Cole, Mar 17, 2006.
  1. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    Palm Jumeirah, Dubai
    +21
    Hi Guys - Just moved the Pio DVD player into the bedroom for use on the spare TV. Moving from a component connection to RGB Scart, but when I put in a scart lead the "AV Connector" option is greyed out. So i'm not able to switch between Video / S Video / RGB.
    Now i'm 99% sure that the scart i'm using is RGB. I know 200% that the TV is ! So any ideas what's causing the problem? I know the manual refers to a specific pioneer AV cable - well that dissapeared at the time of the DVD set up as I went straight to component.
    Or is it just because the lead isn't RGB ?
  2. Benfica
    Benfica
    The problem is that you can not have component and RGB on at the same time.
    You should unselect component video first and then RGB will become slectable.
    HTH
  3. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,095
    +21
    Thanks a lot fella, switching the output back to interlaced enabled me to switch to RGB. :thumbsup:
  4. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
    Ditto, compenent and RGB cannot be used together....
