Pioneer DV575 prog-scan +Epson EMP TW10
F
FaB*Bo*Peep
I am very tempted by Richer Sounds £99.95 deal on the Pioneer DV575 DVD player, but if I do go for this upgrade it would purely be to gain the progressive scan feature.
Although I have read many articles and now understand how progressive scan works to improve the picture quality, I am still not sure if these signals would be compatible with my Epson EMP TW10 projector and that is where I need your help please:
(1) Can the Epson TW10 handle the progressive signals from the DV575 ?
(2) Would the difference in the picture quality be noticeable or are they more noticeable on higher resolution projectors / plasmas etc ?
Thanks in advance for any help offered.
:hiya:
F
FaB*Bo*Peep
Thanks - you saw an appreciable difference over a non progressive scan DVD source ?
PJTX100
Can't lose with Richer, take it back if you are not 100% happy.
But for £100 it's a no brainer in my book. Cracking machine for the price....PJ
M
maxiboy
I also have the above combination and would say that there is a real improvement in picture quality over the RGB Scart feed that I was using. Go for it.
CAS FAN
How does the quality compare against an X-Box as a DVD player running via component using the Hi Def Pack?
Just curious as that's what I use at the moment and it gives a pretty good picture. I was wondering whether it's worth upgrading to a true DVD player?
F
FaB*Bo*Peep
Thanks for the feedback. I will order it tomorrow and will post my thoughts once I have played with it a bit :)
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
