Pioneer DV565
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dave777, Aug 31, 2003.
  1. Dave777
    Dave777
    Oct 25, 2002
    488
    Gatwick
    +15
    Has anyone actually got a Pioneer DV565. I'm thinking of this model now as I may not need PAL prog scan, but it does everything else!
    Dave
  2. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    Just ordering mine tonight...
  3. Dave777
    Dave777
    Oct 25, 2002
    488
    Gatwick
    +15
    Good luck! Please let us know what its like!
    Dave
  4. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    Ordered of Hispek.com
    Although Richer Sounds are now offering them at 199..so I might go with them instead...
  5. Dave777
    Dave777
    Oct 25, 2002
    488
    Gatwick
    +15
    Thanks, I'll have a look.
    Dave
  6. jsebright
    jsebright
    Dec 16, 2002
    57
    Bristol, UK
    Mine turned up yesterday, only had enough time to open the box & have a quick flip through the manual, but it seemed to say that if you set it for progressive on a PAL disc, it would output progressive NTSC. - sounds odd...
    Don't have a progressive display or leads to try this out on, so can't confirm.
    Jon.
  7. kwangomango
    kwangomango
    Jan 9, 2003
    859
    Kent
    +38
    Sounds like it downconverts PAL material to NTSC progressive. My old Philips 963sa had the option to do this. Very useful as i had a Toshiba Strata which only accepted progressive NTSC signals.
  8. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,335
    Has there been any reviews of this player yet ? I've done a quick google search and drawn a blank.
    I assume this is a multi-region player also ?
  9. jsebright
    jsebright
    Dec 16, 2002
    57
    Bristol, UK
    There was a positive review in a recent What Hi Fi? S & V magazine.
    Mine's multiregion, got it from av-land, but I see it's cheaper at hifibitz :(
    Jon.
  10. Duncan Harvey
    Duncan Harvey
    Mar 25, 2003
    953
    43
    Lichfield
    +117
    Got mine today - splendid player
  11. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,335
    A weird question here maybe.....
    Does it allow you to show the amount of time remaining on a film as well as time elapsed ? My current player doesn't do this and it annoys the hell out of me.
  12. lukes
    lukes
    By pressing Display on the remote you can see Chapters, Elasped time, Remain time and total time.
    It's a very good player - I just have a multi-region problem.
    If someone knows the hack can you please let me know
    L.
  13. Rickyj @ Kalibrate
    Rickyj @ Kalibrate
    Well-known Member AVForums Sponsor
    Jan 29, 2003
    5,849
    Surrey
    +1,846
    Have you tried the bass managment out on DVD-A, and SACD, as i have seen indications that it can do both, but would like confirmation.
    Ricky
  14. Dom36
    Dom36
    Aug 26, 2003
    288
    Good ol' UK
    +13
    Why - the player is multi-region anyway...
  15. lukes
    lukes
    It has the chip but needs to be unlocked - wasn't brought as multi-region
  16. tanger
    tanger
    I am thinking of buying this player but would be interested to know what the DVD layer changes are like - are they seamless or noticeable?
    Many thanks to anyone who can help!
  17. lukes
    lukes
    There is a very small delay however much less than my philips
  18. Family Guy
    Family Guy
    You have problems mate...Pioneer players are not remote hackable...you need to scout the internet for someone to do this for you. If you say it has the chip(?), then it will probably involve you hiring a remote control for about £25, firing the code into your player and sending the remote back.
    Problem is, I don't recall Pioneers being made MR in this way...:confused:
  19. lukes
    lukes
    All Pioneers from what I understand are MR but some are locked and unlocked - I happened to have brought a locked one and to unlock it you need to send a remote macro command.
    I guess I confused the matter by saying remote hack - should have said pronto macro code.
    The code I believe my dealer used was this
    http://www.avforums.com/forums/showthread.php?s=&postid=716752#post716752
