pioneer dv55 versus sony dav300
Discussion in 'Home Cinema Buying & Building' started by dean richardson, Aug 2, 2001.
  1. dean richardson
    dean richardson
    which should i go for ? And why ?
    thanks
  2. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    Without doubt the Pioneer. Just pop down to any show room and you'll see, or rather 'hear'. <br />Sony only has a passive subwoofer, Pioneer has an active subwoofer. Plus the satellites are built better and just sound way nicer than the Sony.<br />More AV inputs on the Pioneer for conncetivity.
    Pioneer is slightly more expensive, but well worth it. Difference should be less than £50 if you look around on-line.
    Plus, the Pioneer is sexier <img src="biggrin.gif" border="0">
