Pioneer dv55 replacement, ideas?
Discussion in 'Blu-ray & DVD Players & Recorders' started by dannyjo22, May 4, 2005.
  1. dannyjo22
    dannyjo22
    May 4, 2005
    41
    Hi, new here hope this is in the right place.
    I currently am still using a pioneer dv55 system, 3 or so years old. Recently it has started playing up when playing cdr's. Sometimes the cd keeps playing but the track number stays the same. A few other little faults like that but dvds play fine.
    I'm looking to replace it in the not too distant future for a similar spec player. If possible i would like to keep the sub and speakers i have as they are all nicely run underneath the furniture.
    Any reccomendations on a good replacement (most likely a pioneer to take my old sub connection and the speakers are just the standard speaker cable, no end connector)
    Cheers any advice gratefully recieved on a home cine system or alternative player.
    Danny
