Pioneer dv400 samsung r88 setting
Discussion in 'Blu-ray & DVD Players & Recorders' started by pep411, Jan 15, 2008.
  1. pep411
    pep411
    Dec 26, 2007
    36
    I bought a pioneer dv400, i am connecting it through hdmi.
    I tweaked all the options as per the post on first page of Samsungr88/87 settings post in the LCD section. I am playing the dvd in 720p mode.
    Can anybody please help me with the settings with pioneer dv 400 . At the moment dvd image is quite substandard compared my my sky sd.
    The picture quality is much better when i play the same dvd using my mac mini via hdmi-dvi cable.
    Please suggest me a solution, getting pretty desperate. Had a row with my girlfriend on this player. Picture quality is only way to prove this was good purchase.
  2. blackbird1137xx
    blackbird1137xx
    Jan 9, 2007
    60
    11
    +4
    Though it doesn't help you today,
    I have just purchased a DV400 that should arrive tomorrow for my Samsumg Plasma, I'll see what I find and be in touch
  3. pep411
    pep411
    Dec 26, 2007
    36
    thanks for that blackbird. Another problem. I downloaded some HD 720p clips from stage 6 in divx format. When i want to play it through USB or through CD, i get error message "The video resolution of this file in not supported"
    I am connecting my pioneer dv400-k through HDMI. I tried with a mp3 player via usb no joy same is the case with CD-rw.
    Mp3 player has FAT32 format.
    I am getting frustrated with the player.
    Please suggest a possible solution.
  4. blackbird1137xx
    blackbird1137xx
    Jan 9, 2007
    60
    11
    +4
    Just started reading the online manual and noticed
    "PC-created disc compatibility
    Discs recorded using a personal computer
    may not be playable in this unit due to the
    setting of the application software used to
    create the disc. In these particular instances,
    check with the software publisher for more
    detailed information.
    Discs recorded in packet write mode (UDF
    format) are not compatible with this player.
    Check the DVD-R/-RW or CD-R/-RW software
    disc boxes for additional"
    Don't know if that may be an issue...........will continue reading.....................further reading suggests that the USB will only play jpegs & 2 channel audio from memory sticks etc through the USB not video files
  5. Peopleselbowpad
    Peopleselbowpad
    Jan 13, 2007
    870
    Middlesbrough
    +53
    With regards to DIVX I'm afraid the player does not play HD Divx files. only standard.
  6. fusio
    fusio
    Dec 22, 2007
    2
    Indeed, this is not HD player, so it is not capable of playing HD content. It can only upscale standart (or less) resolution content.
    I use this player for some 3-4 months and I am very satisfied both with the quality of picture and palying almost anything you throw at it.
  7. Peopleselbowpad
    Peopleselbowpad
    Jan 13, 2007
    870
    Middlesbrough
    +53
    I have a R88 with a Xoro 8430 DVD player at 720p and I use these settings except DNIE: OFF and Noise Reduction :LOW or OFF. I have found the picture to be the best I believe I can get out of SD. Have you tried these?
  8. pep411
    pep411
    Dec 26, 2007
    36
    But what about settings in the pioneer dvd player picture menu. Can somebody please post me optimum settings.
  9. Peopleselbowpad
    Peopleselbowpad
    Jan 13, 2007
    870
    Middlesbrough
    +53
    Try with everything turned off on the Pioneer and then turn on each one to see if any improvement.
    I've ofton found most enhancements on DVD players or TV's ofton worsen the picture. DnIE on the Samsung TV I found makes the colours all abnormal and cause Noise on the picture.
    P.s Make sure you have the pictures size as "Just Scan" at 720p that way your supposed to get 1:1 Pixel Mapping even on a 768p TV.
  10. Scrutinizer
    Scrutinizer
    Mar 7, 2007
    580
    43
    +175
    If your picture looks worse at 720p than Sky SD then I suggest you set the HDMI connection on the DV400 to 576i and see what it looks like. After that, compare it to 576p and see which looks better.
    S.
    (at 576i you are bypassing both deinterlacing and scaling in your player (at 576p only scaling) and you are effectively leaving it to your TV)
  11. Ripper^
    Ripper^
    Dec 1, 2005
    406
    +3
    Quick off-topic question regarding the dv400. Does it come with a hDMI cable? If not, what should I be looking to buy? The different types confuse me :confused:
