Pioneer DV340 anyone?
Discussion in 'Blu-ray & DVD Players & Recorders' started by alextgreen, Jan 23, 2002.
  1. alextgreen
    alextgreen
    Apr 17, 2001
    550
    London
    +5
    I just ordered mine from Richer sounds (birthday present, thanks mum and dad) as to my understanding it's quite a nice player and doesn't go totally pear shaped when asked to do CD duty.
    Anyone have any comments/experience on this player?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    No RGB output so you are limited to s-video only
  3. alextgreen
    alextgreen
    Apr 17, 2001
    550
    London
    +5
    According to my sources, Richer Sounds (supplier) and manufacturer, it does indeed have RGB scart out, this is the text off Pioneer's website:
    DV-340
    Twin wave Laser Pickup- separate laser diodes optimised for DVD and CD, with CD-R/RW playback (also plays un-finalised CD-R's)
    Composite + S-Video + SCART outputs
    Slightly slimmer, plus improved display and display lens
    Digital outputs transmits 24/96 data as well as Dolby Digital, MPEG and DTS
    Improved PCB design layout with audio and video sections clearly separated has upgraded the technical performance- such as improved Signal-to-noise and dynamic range
    To my understanding, the model was updated fairly recently.
