Pioneer DV-99 Speaker Covers
Discussion in 'Home Cinema Buying & Building' started by Garion, May 22, 2004.
  1. Garion
    Garion
    Jan 5, 2003
    198
    Essex
    +8
    OK, so we all know the covers come off after a while.....but has anyone tried to fix them back on somehow?
    Don't say take them back,this is an excellent bit of kit and the moving covers do not affect the sound. Replacement speakers will just do the same.
    Only my rear left starts to come forward after a few days, I just press it back and it fixes it, but has anyone tried a permanant fix?
  2. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    A 6'' nail does the trick and also fixes them to the wall firmly. But seriously I am of the same opinion its a great bit of kit and perhaps if we can get a list of just how many owners are affected we might get pioneer to do something about it. I am considering having it brought up on our local BBC radio's consumer programme If only to get Pioneer to acknowledge their is a problem.
  3. seafoodmix
    seafoodmix
    Nov 13, 2003
    121
    My centre speaker has come forward a little, but when pushed back it slowly creeps back forward. Do you know what is behind the cover, is it a compressible sticky gasket thing. I think the system is great and cannot see a replacement that meets my needs. What about a bit of silicon sealant to hold them on?
  4. G Canavan
    G Canavan
    Jan 8, 2004
    176
    Jarrow Tyne and Wear
    I used double sided foam tape from Maplins, did the trick.
