Pioneer DV-868 help with DVD+R DL
Discussion in 'Blu-ray & DVD Players & Recorders' started by Vectraone, Mar 27, 2006.
  1. Vectraone
    Vectraone
    Jun 10, 2001
    43
    Worcestershire
    Having recently bought a Pio 868, which is IMHO a cracking player via HDMI, I am finding that it does not like DVD+R dual layer disks. They seem to freeze on the layer change and then stop playing. The only way around this I have found is to ffwd past the layer change. They worked perfectly previously on my Denon and Toshiba.
    Are there any 868 owners out there that have no problems with dual layer DVD+R? (or -R for that matter).
    PS standard DVD+R work just fine.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I've had mixed results using DL +Rs and like you have had problems with the layer change and in the end gave up bothering with DLs.
    Whether DL -Rs work I have no idea.
