Pioneer DV-757Ai PAL Prog?
Discussion in 'Blu-ray & DVD Players & Recorders' started by judesalmon, Jan 23, 2003.
  1. judesalmon
    judesalmon
    Jan 20, 2003
    53
    Bournemouth
    Does the Pioneer DV 757Ai output PAL progressive scan? If not do any Pioneer decks? and if not, can anyone recommend a PAL progressive deck?
    Many thanks!
  2. garyc
    garyc
    Dec 21, 2002
    848
    Jersey, Channel Islands
    +13
    Pioneer have always said no it can't and it will not. The old 747 could do it with an upgrade.
    But probably one of the best PAL prog decks at the moment is the arcam
    Gary
