Pioneer DV-717, problem.
Discussion in 'Blu-ray & DVD Players & Recorders' started by Shuriken, Mar 18, 2006.
  1. Shuriken
    Shuriken
    Would the kind people of this forum please help me. I have a Pioneer DV-717 and it has started to play up. When you place a disc into the tray an insert it. It attempts to play it but spits the disc back out, I have tried this with numerous discs. But if you have the tray empty it stays in.
    :lease:
  2. calibradtm
    calibradtm
    Jan 29, 2006
    2,040
    rotherham
    +48
    that happens on mine but only when the disc region isn't matched to the player.have you put in a disc with a different region to the player?
  3. Dom996
    Dom996
    Jun 3, 2005
    1,061
    +29
    Probably the laser. I have seen a fair few fail in the last couple of years and so far it's works out to be an uneconomical repair. Maybe time for an upgrade.
  4. Shuriken
    Shuriken
    Tried different region discs and I've also changed a switch at the back from PAL to NTSC. Then I changed it to Auto. It has spat out DVD's , music CD's, mp3 discs and VCD's. When I listen to it I hear it start the motor up and warm the laser, but then it stops and spits the disc out.
  5. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
    Try inserting a laser cleaner, have you ever cleaned it?
  6. Dom996
    Dom996
    Jun 3, 2005
    1,061
    +29
    That may have a temporary effect, but a laser that would seem to be that knackered, it will be short lived.
