pioneer dv 696 or panasonic dmr ez25
D
dean01
hi
advise please on these players. is it worth getting the panny ahead of the pioneer on the fact it upscales digital tv??or will the pioneer upscale dvds better as its main function is upscaling dvd or is there another upscaling player to better both these for around the same price £250..max i dont want to spend more due to hd players coming out shortly but have a pioneer 506xde tv and wish to watch pictures to its maximum potential thanks in advance dean
PeteD64
Have you considered a dedicated external video processor/scaler box? The scaling in the DMR EZ25 is probably no better than what your TV is already doing.
If you're serious about getting the maximum potential out of our display then this would be the best option. They are quite expensive but it should handle all your video sources & if you buy the right model it will still work with an HD player.
I can't offer you any detailed advise on them but there's a dedicated forum on here with lots of info.
D
dean01
thanks for reply but dont want to spend that much money with hd players just round the corner
