Pioneer DV-668AV-S or Denon DVD-2910?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Evil Desires, Oct 30, 2004.
  1. Evil Desires
    Evil Desires
    does anyone own any of these 2 dvds players ?
    I am stuck on which to choose as i need a HDMi compatible player for my new pannasonic AE700 projector.
    Is there a big difference in picture quality when useing HDMI rather than RGB scart or component
    Any info would be great?
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    I've recently upgraded my Pioneer 668 to a Denon 3910 - I can't comment on the 2910, but I'd have to say I'm happier with my Denon. Hard to make a comparrison on the picture differences as I can't easily run the two together but i'd say the Denon has a slight edge, with the picture appearing more detailed. The biggest difference I noticed was due to the Denon buffering, no layer change has been spotted on disks I've played. I'd also say that the SACD performance on the Denon was better.
    Sorry I can't compare the 2910 for you, but if I knew then what I know now (and it was out) I'd definitely have chosen the Denon over the Pioneer.
  3. russ123
    russ123
    Jul 31, 2004
    832
    46
    South Of The River
    +110
    I've had a 2910 for a couple of weeks and so far very happy with it :) . Tried it with dvd's, dvd audio and sacd and pleased with all. Until I get a projector I am using the RGB scart output and the quality is great though I am comparing it to a 5 year old pioneer 626. The only downsides to it that I have found are that it does take longer than I had expected to load a disc, it is very unforgiving of marked discs and finally it does seem to generate a surprising amount of heat. Having read other posts, however, these seem to be classic Denon traits.
  4. bobbypunk
    bobbypunk
    The Ptae700 is very good with HDMI try the Arcam DV79 for even better picture through it!
  5. Evil Desires
    Evil Desires
    Thanx for the replies,
    As my dvd player budget is around £500 i won't be buying a Arcam DV79 as there £999
    Think i'll go for the denon
  6. Noger
    Noger
    Got my new 2910 over the weekend. It replaces a Samsung 745. Was going to go for the Samsung 945, but I got bored waiting, and I am glad I didn't in the end. The remote actually works from where sit, and the operability is soooo much easier.
    Picture is very good via DVI, better than scart or component ? Oh yes, but it is a double edged sword, the Samsung was awful on badly encoded DVD's, the Denon is still showing a little Edge Enhancement on some DVD's (Kill Bill Vol 2) but no where near as bad. Can always drop down in resolution to get rid of it.
    Overall I am very please with it, easy to set up and use, great picture, and the ability to play with the different modes (1080i/50hz vs 1080i/60hz) is great. Not great sound with CD's though , although that maybe down to me not having sorted the amp properly.
