Pioneer DV- 656 A / PLVZ1
Discussion in 'Blu-ray & DVD Players & Recorders' started by John Stewart, Jul 18, 2003.
  1. John Stewart
    John Stewart
    Please can any one help with this one?
    I bought a DV 656 based on a review in issue 108 [Nov' 02] of Home Entertainment Mag' which stated it has NTSC progressive scan and it could be enabled for PAL progressive.Pioneer tell me it
    does not do progressive and the Mag' has given wrong info'.
    As most of my DVDs are region 2 anyway, perhaps it is not worth bothering about PAL progressive with the PLVZ 1/DV 656 combination,any one got any thoughts?
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Well PAL progressive is a significant increase in pitcure quality, one that What Hi-Fi describe as equivalent to the change between Composite Video and RGB Scart.
    The review you read was of an american player - which happens quite a lot lately in magazines (this month's What Video TV test an American AVR1803).
    In all honesty I'd get your PLVZ1 first and go from there - although in all honesty you're unlikely to find need to complain about picture performance.
  3. Mr 928
    Mr 928
    John,
    The DVD656 is NOT a progressive scan dvd player. We thought long and hard when we bought this for our shop, do we go for Progressive or DVD-A / SACD...and the sound won!! We use this along with the excellent Sanyo Z1 via a good quality component cable and it works a treat. NTSC and PAL material works great, and we are running a 92"x52" 16:9 screen!! :eek:
    Just not sure if Progressive Scan with the Z1 will make such a huge difference - now with a Sony 12HT it may be worth the investment?!
    Hope that helps!!
  4. John Stewart
    John Stewart
    Hi Dimmy,
    Thanks for your input.Actualy I have already bought the PLVZ1 so
    I think it's time to unbox the DV656 fire up the combination:)
    John
  5. John Stewart
    John Stewart
    Hi Mr 928,
    Thanks for taking up this one.I too am using a similar sized screen to you, so I am encouraged by your positive comments and
    I will live with the combination.The real test is if I can become absorbed in the movie and forget the technology.:)
    John
