Pioneer DV-575A
Discussion in 'Blu-ray & DVD Players & Recorders' started by Xstyle, Dec 3, 2004.
  1. Xstyle
    Xstyle
    Sep 27, 2004
    3,445
    Berkshire
    +143
    Is the Pioneer DV-575A the best dvd player upto £150???
    I've read the review on the link above... and does sound good!!
    But are there any better contendors, in the price range?
  2. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    i got my 575 last week and it whoops the azur 540d it replaced well worth the £120
  3. kasumi
    kasumi
    Sep 22, 2004
    871
    wigan
    +33
    I too bought one last week from Richer Sounds £119.95
    I tell you, best money ever spent, and I've spent some serious money over the years!
    Improvement over £500 older sony is immense.
    Connected to my Pioneer 2011 THX amp, sounds great too.
  4. vectrasri99
    vectrasri99
    Are you people using progressive output?
    Where they RCE multi region for that price and is it auto changing of region?
    M
  5. kasumi
    kasumi
    Sep 22, 2004
    871
    wigan
    +33
    yes, yes and err yes!
    good ey
  6. chic
    chic
    Jul 1, 2001
    5,975
    glasgow
    +871
    had my player for about a week now and i am very happy with it the progressive picture is very good, i replaced my old tosh 510 and the picture is on a par with that and i paid £300 for that and it only did ntsc progressive, where the pioneer does pal and ntsc progressive, with the added bonus of divx which works very well
  7. denden
    denden
    Take a look at Philips DVP-720 AS, great audio, great video, and great divx with subtitles. I heard that Pioneer can not play divx subtitles. If you do not need subtitles with divx, stay with Pioneer.
  8. nwgarratt
    nwgarratt
    May 5, 2002
    26,337
    +2,841
    I believe the new 575 frmware adds divx subtitles .
  9. Mr_Fantastic
    Mr_Fantastic
    Nov 5, 2004
    605
    28
    +51
    Subtitle problems with DivX players seems to be extremely common for some reason, I've seen it mentioned on just about every DivX player I've looked at. It seems to be added after release by firmware updates for some reason.
  10. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Does the 575A play all kinds of DivX & AviD disks? I currently have the Yamada 6600 player which does play both very well. I'm just thinking that I'm missing out on something even better!
  11. Rob100
    Rob100
    Nov 3, 2002
    3,468
    +227
    I have both the Yamada 6600 and the Pioneer 575.
    Firstly you can't compare the build quality, the Pioneer is much better, but then it's over twice the price so you'd expect that.
    I haven't tried an extensive amount of MPEG4's, but it seems what one plays the other will.
    There are a number of discs (Xvid's) I have that won't play (well they play, but stutter/jerk terribly) on the Yamada and likewise have the same problems on the Pioneer. Having done some encoding tests of my own it seems to be files encdoded with 2 successive b frames that causes the problem. This is the default for Xvid so that explains why they've been encoded like this, but if you look at the DivX home theatre specs this only allows for 1 successive b frame.
    Rob.
  12. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    The stuttering is caused cause of the packed pit stream, per my previous posts :
    "Every Mediatek based player has problems with xvid+bvop>1+packed bitstream
    enabled. Unfortunatly thats the default in Xvid 1.0.
    You can set bvop=1 or disable packet bitstream to solve the problems.
    Theres also a tool wich can remove packet bitstream afterwards without
    reencoding: http://www.moitah.net"
    Also the 575 firmware update adds ogg support and subtitles for divx and works very well so far :)
  13. tuttonp
    tuttonp
    Jun 10, 2003
    6,277
    83
    Bristol
    +237
    Recently purchased a 575 to replace my 565!!. No major differences though the stated GUI changes are nowhere to be seen.
    Any idea how I
    A. Find out what Firmware I have
    B. Understand which firmware provides OGG support
    C. Work out how to flash the f/w without borking the macjine or losing the M/R capabilities.
  14. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    A : "to get the firmware version of your player you need to highlight the word 'Options' in the set-up menu, then press display on your remote control"
    B : 2.09 is the updated firmware from Pioneer
    C : Flashing new firmware on the 575 and 470 does NOT effect if your player is multiregion or not. E.g if your machine is M/R now, you can flash the update and it will stay M/R.
  15. tuttonp
    tuttonp
    Jun 10, 2003
    6,277
    83
    Bristol
    +237
    Next daft question is - "how do I go about flashing the firmware???". Is it a simple case of downloading from pioneer, burning it to cdr and then invoking an upgrade via remote keystrokes??. Pointers would be appreciated.
  16. chic
    chic
    Jul 1, 2001
    5,975
    glasgow
    +871
    you can download the latest firmware from here you then use nero to burn the image file, you then put the disc in the player it then automaticaly updates the firmware, instructions come with the download,
    i updated my player which i bought from richer sounds and the multi region stays intact
  17. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,872
    Falkirk, Scotland
    +833
    I downloaded firmware for my 575 here...
    http://www.avland.co.uk/pioneer/dv575/dv575.htm
    It comes with a small readme which tells you exactly what to do. The readme states that you drop the disc in and wait for the player to do the business. At some short point afterwards it ejects the tray and at this point you must remove the disc. Leave the tray open just make sure you remove the disc.
    It seems to take an eternity and the screen shows Upgrading Firmware ( or words to that effect ) but at this point the player is upgrading itself. It is very important not to interfere with the player duringthis process. After this time the player will reboot itself and all should be well.
    Lets face it flashing the firmware on any of your devices can always be a brown trouser type affair.
    Hope thi shas helped.
    Keith Hurst
  18. movie_fan
    movie_fan
    Dec 18, 2004
    400
    +8
    You mean Ogg Vorbis sound files? I upgraded my 575's firmware just this morning and I didn't know that it also supported Ogg Vorbis...
  19. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    I've not tested it buy on divx forums, surdvd and a few others people say they got ogg and ogm working on the 470 / 575.
  20. BigAde
    BigAde
    Jul 22, 2002
    964
    East Sussex
    +23
    Anyone know the best internet place to get a multi-region 575 ?
    I don't have a Richer Sounds anywhere near me, so preferably online.
    Pixmania are doing it for £110, but not MR...
    any suggestions?
    Thanks.
  21. allanp
    allanp
    Jun 28, 2004
    1,029
    48
    +94
    If you have a pda such as a pocket pc or palm, you can make it region free for free.
  22. mattross
    mattross
    Oct 23, 2004
    257
    +6
    I bought mine last week on www.rgbdirect.co.uk for £119 multi-region, not had it delivered yet though. I just noticed they have since put the price up to £128.95. Empire Direct have it for about £120 as well but they won't have any in stock until January. A warning about Pixmania [who have increased their 575 price to £115 now], I think they ship from France and usually U get the manual in French. At least this is how it was the last time I was hooked by their cheap prices on digital cameras, maybe they've changed.
  23. BigAde
    BigAde
    Jul 22, 2002
    964
    East Sussex
    +23
    Thanks... will steer clear of Pixmania then.
    Don't have a PDA, but know a man who does... think its an IPAQ, is it a simple thing to do on a PDA?
  24. Lek
    Lek
    I only used a Palm to "free" my Pioneer DV-470, but the procedure for an IPAQ should be similar. Check the forums on VideoHelp.com, and get the .CCF file from Remote Central. Note that the same hack seems to work for all the newer Pioneer models, so check the other VideoHelp Pioneer posts for more information. You'll also find instructions for using a laptop or PC with an IrDA port in there, so a PDA is not strictly necessary if you've got one of those.
    Good luck.
  25. BigAde
    BigAde
    Jul 22, 2002
    964
    East Sussex
    +23
    Thanks Lek...
    Yes, have a laptop with an irda port, so will use that... thanks a million!
  26. fire boy
    fire boy
    Dec 14, 2004
    279
    London
    +7
    I have the old pioneer 565 dvd player and have just purchased a panny pd50 36" tv.
    Would an upgade to a 575 be justified in terms of picture quaility?
  27. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    I have the old(er?) 525, driving a PJTX100 projector via SVHS. Just bought the 575 from Richer, mainly for prog scan and component (525 doesn't have component outputs).
    The more I see the 575 picture (only had a few days) the more I appreciate how "cleaner" it is. Not a massive leap forward, but an advance nonetheless. Also nice to have the ability to give DVD-A and SACD a try.
    For under 120 quid it's a bargain...
  28. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,426
    Yeovil
    +218
    I know people rave about Pioneer and how good they are and I'm certainly not knocking this dvd player but when you think about it almost everything about it is chinese. The mediatek chipset, the firmware and I bet construction are all chinese. Its possibly Pioneer wrote the firmware for the player but its much more likely that it was programmed by Mediatek for Pioneer and even if Pioneer customised it the core firmware will be mediatek.
    There is almost nothing japanese about this player at all except the badge and the styling.
    I'm not saying this is a bad thing but its a sign of the times that I find quite interesting.
  29. trailer
    trailer
    Dec 22, 2004
    2,863
    +231
    I bought a 575 off RGB a couple of weeks ago for £122. Excellent service
    The player.....
    Feels a bit plastic....doesnt look anything special.......
    Plays like a dream...........looks and sounds fantastic
    Especially good on DVD- Audio. Im currently running it through a Naim / Linn front end and a Cambridge Audio Azur 540 R for the rears and centre. (Linn 5110s and a B&W VM1). The sound is well balanced and the bass is very deep, but not overblown.
    Picture quality is very good although I haven't tried the progressive outputs...just the RGB.
    All in all a bargain for £120...and it can play SACD DivX etc etc........no need for an upgrade for a while...........ahem
  30. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    I'd be 99% sure Pioneer don't make the firmware and get Mediatek to do it. From what I've read elsewhere Mediatek have a good income from firmware.
