Pioneer DV 575A problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bikertone, May 3, 2005.
  1. Bikertone
    Bikertone
    Got two problems with the 575:
    1) I bought the thing under the impression it was multi region capable. What they meant was it could be multi region after being tweaked!! Anyone know how to do it please??
    2) The mchine auto shuts down after 30 mins and I lose the resume function. Is this a fault or the way its designed?? Is there any way I can disable the auto shutdown??
    I have another old pioneer model that doesnt shut down and the resume stays up as long as the machines switched on.
    I even rang Pioneer UK about this and they hadnt a clue!!
    Tone
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    AFAIK, there's no remote hack. There's two ways around this.
    1. Pay upwards of £20 to 'rent' a remote that will make it multiregion
    2. Get a hold of a Pronto or PDA and do it yourself.
    As to the 30 minute shutdown thing. I'd imagine that's the way the machine is. Perhaps another owner could shed some light?
    I had a Sony player that used to go into standby if not used for 5 minutes but never shutdown. I was always able to use disc resume no problem.
  3. gamerfreak2002
    gamerfreak2002
    Oct 6, 2004
    46
  4. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    I have just tested the resume on mine after stopping the film and waiting for the 30 minute shutdown and it resumed OK
  5. Grand Dizzy
    Grand Dizzy
    Dec 11, 2004
    311
    I'm about to buy this DVD player. Annoyed to hear there's no code you can put into the remote to make it region free! :(
    Why do manufacturers make region-specific players? Are they paid off by movie companies or something?
  6. sy278
    sy278
    Jul 4, 2004
    506
    28
    Glasgow
    +39
    Short answer yes they are!
    Buy it from Richersounds (www.richersounds.co.uk) already modded to multiregion, which is better than region free.
  7. mattross
    mattross
    Oct 23, 2004
    257
    +6
    U can make it region free with a remote. I did it with my Pronto 950 when I had a 2.09 firmware on it. Take a look in the player hacks section.
    The latest MTZ firmware lets U select the region U want it to be from the menu: http://mtz.softpedia.com
  8. lordnoize
    lordnoize
    Dec 4, 2004
    142
    16
    thanks for that!
    saved myself £20 with that firmware
    has anyone had any experience of using this new firmware?
  9. Geesus
    Geesus
    Dec 23, 2003
    1,690
    +421
    Seems to improve xvid playback and makes titles like South Park: BLU (R1) actually play, whereas the retail firmware caused it to hang on the menu screen.
  10. Craig
    Craig
    Apr 2, 2004
    295
    Copenhagen
    +4
    Sorry to be really thick......but
    when I open this file I find a *.bin file, and when I try to copy it on Nero Burning ROM I get a message that says "unexpected file format"
    What, I wonder, am i doing wrong (this time) ??????
    Can anyone help?
  11. rickardl
    rickardl
    Sep 9, 2004
    684
    46
    Stockholm
    +127
    1. Create a CD-ROM (ISO): (Data mode: Mode 1 File system: ISO9660 + Joliet)
    2. Label it "PIONEER"
    3. Put the .BIN file in the top/root directory
    4. burn it with 'Verify' turned on.
    then
    5. insert the disc into the player
    6. press 'Play' when prompted
    7. remove disc when it is ejected automatically
    8. wait a minute
    9. the player will reset when done so make sure you change whatever
    settings you had changed in the setup before.
    it works with a CD-RW as well as a normal CD-R.
  12. Craig
    Craig
    Apr 2, 2004
    295
    Copenhagen
    +4
    Thanks Rikard, you're a star :clap:
