Pioneer DV-575A how do I make multi region?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bikertone, Jan 1, 2005.
  1. Bikertone
    Bikertone
    Just bought the above machine and am pleased with it but all internet searches say its multi region but it only plays region 2 dvd's Anybody any ideas how to make it multi? Nothing in the manual. Cheers
  2. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    243
    Depends if you bought the region 2 or the multi region version. The region 2's are about a tenner cheaper. But take it back to where you bought it from and get them to update it to multi-region for you.
    Fish
  3. Bikertone
    Bikertone
    Thanks for the reply got it from Empiredirect off the net. Checked a lot of sites first though and model number supposed to be multi region. If I cant sort it I'll ring the manufacturers Cheers
  4. EmissarY
    EmissarY
    Please dont get confused. When the Pioneer comes from the factory it is NOT multi region. The Pioneer 575 (silver or black) is modded by the retailer that sells it, thus there is no specific model number to separate a multi region one from a normal region 2. They are ALL region 2 when they are made by Pioneer for the UK market.
    The only option u may have is to send the model back and pay the extra for a multiregion upgraded unit.
  5. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    35,074
    Bristol
    +8,421
    There is no standard remote control region hack for the Pioneer, you need to get it done by the retailer which is what I did when I bought my DV470.
  6. Bikertone
    Bikertone
    Thanks for commentsfolks much appreciated.
  7. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Hi:
    Have you got a Palm Pilot or a PDA? If so, take a look at www.videohelp.com There is hack in there to make the Pioo 575 multiregion using a palm pda.
    Regards,
    J. Rosado
  8. geoxen
    geoxen
    Would it be possible to place the so called hack for the multi region codes,via IR with a regular PC or does it have to be a palm?
  9. Eitzel
    Eitzel
    Nov 3, 2004
    663
    46
    Top Secret-Anyone coming anywhere near my Pioneer
    +145
    Check this out for a remote:-
    http://www.pioneer-remote-hack.co.uk/
    :smashin:
  10. gamerfreak2002
    gamerfreak2002
    Oct 6, 2004
    46
  11. geoxen
    geoxen
    The info you guys provided are great, thanks a ton. Let you know if all worked out well :thumbsup:
  12. geoxen
    geoxen
    Gamerfreak you're my hero!! Thanks a lot mate, works perfectly. I hope there aren't any side effects!! :smashin:
