Pioneer DV-575 Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by AgentCool, Oct 6, 2004.
  1. AgentCool
    AgentCool
    Aug 5, 2004
    2,653
    Yorkshire
    +184
    I've had a Pioneer DV-575 for about 2 months now and the list of problems with it is growing. The things I have noticed wrong with it so far are as follows:
    1) Almost continuous horizontal banding when playing a 2.35:1 ratio film. Particularly noticable in brighter scenes.
    2) Jumpy playback on 'Welcome to the Jungle' around the 1 hour mark. Sometimes freezes altogether.
    3) Will not play Episode 4 of 'That Peter Kay Thing'. Just starts the episode and then freezes.
    With points 2 and 3 there is definitely nothing wrong with either disc because I have tried them on 3 other DVD players and they play perfectly.
    I have the player connected to a Toshiba 24Z33 widescreen CRT TV using a QED P2110 RGB Scart lead.
    Has anyone else had similar problems with this player? I'm starting to wish I hadn't sold my old Panasonic DVD/VCR...
  2. Kish Kash
    Kish Kash
    Ah yes, the ol' Pioneer RGB Scart curse!!
    Forget it mate. Nothing you can do about it. its a design fault that afflicts almost all pioneer dvd players, from the 464 to the 757. Welcome to the club!
    Major, major pain in the bum, I know. All I can recommend is using s-video or investing in a tv that has component inputs (i.e. plasma, or most toshiba 16:9 toshiba crt's).
    There are loads of threads in this forum about the problem. just type in "565 banding" and you'll get lots of results.
  3. sharper
    sharper
    Jul 24, 2002
    609
    SW London
    +11
    A long shot. turn the thing off and on at the mains and see if that works..
