Pioneer DV-575 DVD component connection to DLP Optoma EP737 Projector
Discussion in 'Projectors, Screens & Video Processors' started by gsi66, Jul 28, 2005.
  1. gsi66
    gsi66
    Hi Folks,
    I have an Optoma EP737 DLP projector which I would like to connect to a Pioneer DV575 DVD player using the Y,Pb,Pr component connectors. I bought a cable with Y,Pb,Pr on one end, the other end is a D-sub VGA connector. However, my projector ignores this source.
    I have configured the component out and set the progressive scan option on the DVD. If I connect just the yellow video out to the yellow video out on the projector, the projector registers the source and I get a picture (composite), but I really want a component connection.
    The projector only has the following ports:
    (a) monitor loop through (VGA connector mentioned above);
    (b) RS232 input;
    (c) Composite video connector (yellow photo video in);
    (d) Audio phono;
    (e) S-Video (round);
    (f) VESA M1-DA Analog RGB / Digital / HD-TV / Component Video / USB Mouse input;
    I cannot help thinking that the option (f) is really what I need, but can you get a Y, Pr, Pb component cable with an M1-DA that would work?
    Any ideas would be welcome as I am in the dark...
    GSi
  2. fruitcakegsi
    fruitcakegsi
    Feb 20, 2008
    4
    Hi GSi66 what a co-incidence we have the same userid !!
    Okay, you can get an M1-A -> HDMI converter and connect to the PS3 directly. However it does not work. This is because the PS3 output's HD 1080i as a digital feed (via the HDMI) which the projector can only do HD 1080i via analog - ergo the component cable is needed.
    So, obtained an M1-A component cable, linked it to the PS3 via component and Bob really is your uncle - HiDef 1080i from the PS3 to an Optoma EP737 wonderful.
    Now I don't have to go out and buy a HDMI hidef projector - the Optoma is just as good.
    Word of warning though, if you play ordinary DVD's through the PS3 with upscaling on, it will not upscale over component. Blu-ray is fine though.
  3. citrac
    citrac
    Aug 5, 2003
    96
    Does this answer mw question I wonder. I didnt install an hdmi lead when I first ceiling mountedmy projector (infocus 4805). Can I pass hidef from a ps3 to my projector ?( I may upgradeto a 720 p such a sthe optoma 65)
