Pioneer DV-565A - Multi Region hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by lukes, Sep 2, 2003.
  1. lukes
    lukes
    I was woundering if some could advise me on how to hack the Pioneer DV-565A to run multi-region disks.
    I belive this can been done by using the remote or a pronto remote data file.
    Luke
  2. JUS
    JUS
    Jan 21, 2003
    3,200
    Plute
    +239
    I've been told the hack is the same across the whole of the Pio range. Not sure what the hack is bit it might help :)
    av-land are selling me a hacked one at no extra cost.
  3. nealgs
    nealgs
    Are Pio doing handset based hacks now?? as previously they were all Firmware or hardware mods required to make em mult-region
    eg my 525 had a firmware mod to it for MR, whilst others had multimod mods done.
    just wondering
    cheers
    Gary
  4. lukes
    lukes
    It has the chip but it code needs to be unlocked - I'll pop into the dealer as I know they have the pronto commands - they did it to my bro's 303 about 3months ago
  5. mseabroo
    mseabroo
    Aug 28, 2001
    376
    28
    Sussex
    +41
    You could try sending the following from a Pronto or other programmable remote.
    Don't know if this will work on the latest generation or players or not. Fortunately my older pio was already multi region so have been unable to verify that this code is completely correct personally.
    hope it does the trick for you though.
    0000 0067 0050 0000 0154 00af 0016 0040 0016 0040 0015 0015 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0016 0040 0016 0040 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0016 0040 0016 0040 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0016 0040 0015 0015 0015 0015 0016 0040 0016 0040 0015 0015 0014 045d 0154 00ae 0016 0040 0016 0040 0016 0040 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0016 0040 0014 045d 0154 00ae 0016 0040 0016 0040 0015 0015 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0014 00af
    Now if we could find a way to enable Pal prg scan I might be tempted to upgrade myself.:)
  6. lukes
    lukes
    That looks like the one but got my local supplier to do it for me.
  7. The Boogerman
    The Boogerman
    Dec 22, 2001
    39
    Bavaria
    mseabroo, tried your suggestion via pronto to my 565, and it worked a treat, tried region 1, 2, 3 and 4 disks and they all worked perfectly.
    Cheers!!
