Pioneer DV-474 includes Divx support ?!
Discussion in 'Blu-ray & DVD Players & Recorders' started by NX3, Jun 16, 2004.
  1. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    "DV-470, adds DivX, an optical digital audio output, and 12-bit, 108MHz video DAC’s to the spec list."
    http://www.avland.co.uk/pioneer/dv470/dv470.htm
    Nothing on Pioneer page yet...anyone know anything about it divx compatibility ? What the chip inside is ?
  2. FlimsyFeet
    FlimsyFeet
    Oct 18, 2003
    91
    DivX® video playback (DV-470 only)
    About DivX
    DivX is a compressed digital video format created by the DivX® video codec from DivXNetworks, Inc.
    This player can play DivX video files burned on CD-R/RW/ROM discs. Keeping the same terminology
    as DVD-Video, individual DivX video files are called “Titles.” When naming files/titles on a CD-R/RW
    disc prior to burning, keep in mind that by default they will be played in alphabetical order.
    DivX video compatibility
    • Official DivX® Certified product.
    • Plays DivX® 5, DivX® 4, DivX® 3 and DivX® VOD video content (in compliance with DivX®
    Certified technical requirements).
    • File extensions: .avi and .divx (these must be used for the player to recognize DivX video files).
    Note that all files with the .avi extension are recognized as MPEG4, but not all of these are
    necessarily DivX video files and therefore may not be playable on this player.
    • Media: ISO 9660* formatted CD-R/RW/ROM
    * ISO 9660 Level 1 or 2 compliant. CD physical format: Mode1, Mode2 XA Form1. Romeo and Joliet
    file systems are both compatible with this player.
    • Multi-session playback: No
    • Unfinalized disc playback: No
    • File structure: Up to 299 folders; up to 648 folders and files combined per folder.
  3. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    has noticed files that are 23 fps wont play but will if they are 29fps
  4. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    Have you tried a Xvid ?
    Do you know what the divx decoding chip is ? (i.e have u had a look inside?)
