Pioneer DV-470 Component Output
Discussion in 'Blu-ray & DVD Players & Recorders' started by locutus, Jul 23, 2005.
  1. locutus
    locutus
    Sep 28, 2003
    74
    Southend-on-Sea
    I have just bought a Samsung 40" LCD TV that has component inputs but when I connect my Pioneer DV-470 to it via the component outputs I get No Signal.
    Cant see what I am doing wrong but not getting anything. RGB scart works fine, just the component thats not working.
    Any ideas?
    Konrad
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    On most DVD players (well all those I've owned) you can have component or RGB output, but not both. To get the component to work you need to set the video output to composite or S-Video. Component should then kick into life!
    HTH,
    Mark.
  3. Slimchandi
    Slimchandi
    Dec 23, 2004
    467
    +3
    Might be something to do with the progressive signal, check you've got your dvd and plasma either both set to progressive or interlaced.
  4. locutus
    locutus
    Sep 28, 2003
    74
    Southend-on-Sea
    Mark thanks
    That worked a treat and my god it looks good!!!
