Pioneer DV-444S
Discussion in 'Blu-ray & DVD Players & Recorders' started by sam_a, Jun 5, 2002.
  1. sam_a
    sam_a
    On www.whatvideotv.com it mentions this player supports VCD discs - is this the case?
    I have a few VCD's so its fairly important for me.
    Sam
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    As far as /i know, try www.hifibitz.co.uk where I got mine MR. They should be able to tell you exactly.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    That's the silver finish version isn't it?
    The 444 supports both original VCD's and home produced VCD's and it also plays SVCD's.
  4. DyManiX
    DyManiX
    May 29, 2002
    88
    3
    +7
    Yes it plays them very well, but the fast forward isnt very fast on Video CD's.
    I use mine to watch home made SVCD's, apparantley its one of the few DVD players that will play CDR VCD's and SVCD's back properly.
  5. sam_a
    sam_a
    are the MR ones modded by the store or are they normal pioneer products?
    Sam
  6. DyManiX
    DyManiX
    May 29, 2002
    88
    3
    +7
    They are modded by the shop, so that they automaticaly change region and play RCE disks. Usually macrovision is disabled too.
    Pioneer and the other major brands do not make multi region players.
    Although the 444 does have a menu to change country, I dont know if this changes the region too. Either way it would be well annoying to have to change the region manually each time.
  7. sam_a
    sam_a
    I have just been told by hifibitz this DVD player has been discontinued - what is the replacement?
    Sam
  8. DyManiX
    DyManiX
    May 29, 2002
    88
    3
    +7
    What the 444 discontinued?
    I hope not, I only just got mine!
  9. deets
    deets
  10. andypandy
    andypandy
    Feb 6, 2002
    594
    Surrey, UK
    +10
    maybe a great player, but quite a few people are now beginning to complain about the light shades on he upper part of their screens in RGB mode.
    I wonder whether they discontinued it for that reason ???
  11. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    It's been available for a year which is about standard nowadays before the next model comes out.
