pioneer dv 343
Discussion in 'Blu-ray & DVD Players & Recorders' started by ratty, Jun 27, 2002.
  1. ratty
    ratty
    can anyone tell me if a pioneer dv343 multiregion converts the ntsc signal to pal or not as my tv is pal and only plays ntsc in black and white so i would need to get a converter if it does not,
    also if anyone knows where to get a cheap ntsc to pal converter if i need one that would be cool to
    thanks
    Andy
  2. Justin@UH
    [email protected]
    Feb 21, 2002
    2,193
    63
    Location location location
    +96
    If its a R2 DV343, then regardless of a M/R mod, the machine will convert NTSC to PAL60. Its in the manual, under TV connections:)
