pioneer dv-340
Discussion in 'Blu-ray & DVD Players & Recorders' started by wazz, Jun 1, 2001.
  1. wazz
    wazz
    Has anybody seen a review or have any info on this machine.
  2. samhassall
    samhassall
    I have just received my player, and it is excellent, Pioneer seem to have taken off all the frills and focused on quality. I am using mine with a Toshiba 28WD98 and there are no incompatibility issues at all.
    The navigation with menus player is very good, and even the remote makes sense, even if the button icons are a little small.
    I had mine converted by Multiregion Magic, and the player is very easy to use with all regions, including RCE, with no disc swapping or codes needed. It changes region automatically for non RCE discs, and for (only some) RCE discs you need to press two buttons on the remote to select region one! Overall highly recommended, and a bargain at £179.00 including VAT.
