killermadal
Hi All,
I have just purchased the Pionner dsc-353 on the recommendation of 'What tv/dvd' mag and after installation found that it can't paly 5.1 surround sound via my sky hd box or my tv. It seems to only play the front speakers and sub woofer via the the tv and it is really pis**d me off. I can't return the system as the vendor will not take back the systems as it has been opened and used and i don't want to spend another £200 on another system to replace a brand new system. I feel like have been that is not what it appears to be, i want to buy and thought I was buying a home cinema system but it seems that i have bought a dvd cinema system that only plays 5.1. quality sound via a dvd and nothing else.
If you are thinking about buying the pioneer dsc-353, DON'T, go for a real home cinema system.
