Pioneer DP-435XDE Connection Query
Discussion in 'Plasma TVs Forum' started by Damo9424, Jun 11, 2005.
  1. Damo9424
    Damo9424
    I have read on here that there are 2 cables between the screen and the media box, are these the 2 DVI cables (Tied as one) or is there a power cable as well. And are they dead on 3m long ?
    Also, does any one know if any John Lewis stores stock this model and would they price match ?
    Damo
  2. stormorbit
    stormorbit
    There are two cables which go to the Plasma Screen, the 2 DVI cables (Joined Together) and the power cable. That's it... Not sure about Lewis Price Match, I got mine a month ago from www.beyondtelevision.com/. 2 Year guarantee and delivered the very next day! £2,500. What a picture!...
  3. Damo9424
    Damo9424
    Thanks for that, I am intending to order mine next week with the pioneer tilting wall bracket. Am I being mad buying this expensive bracket as opposed to a universal ? What bracket have you used ?
  4. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    The Joined cable is a DVI and a control cable that is similar to a HDMI connection.
    I use a Vivanco tilting wall mount that cost me £50 months ago and it does the job a treat, worth every penny!
    Don't go wasting your money on a rip off bracket when you can put your funds elsewere on interconnects!
