Pioneer dcs313: Region 1 Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by bodaboda, Aug 3, 2004.
  1. bodaboda
    bodaboda
    I purchased the Pioneer dcs313 player about a month ago from Richersounds, the player works fine, that is until I put in a region 1 dvd or a SVCD.
    The picture goes black and white and very grainy. Even the "Pioneer" boot logo stays black and white until I put a Region 2 DVD back in.
    (I have tried it with 2 TV's and both SCART and composite out no luck)
    Is there a quick fix to this problem or has the richersounds multiregion hack gone wrong or do I have to lug the player back to richer sounds (again).
  2. butch9850
    butch9850
    I have the same problem with region 1 discs>>>>>
    not black/white or grainy....
    but terrible picture/sound....total difference from region 2.
    black.white/grainy...
    Your tv must not be able to play ntsc region 1...(it goes black/white).Is it old???....
    That's the common answer from technicians on that....
    I don't honestly know,about my pioneer dcs 515.....i am pointing towards the multiregion upgrade,as my fault.
    I don't know about yours.
