Pioneer DCS-424 Reviews
Discussion in 'Home Cinema Buying & Building' started by krupatel, Sep 2, 2004.
  1. krupatel
    krupatel
    May 29, 2004
    64
    Anyone had first hand experience of this system?
    I'm particularly interested in if the 3-spot speaker system really works. I am considering purchasing this for my forthcoming Panny TH42PE30B.
    Your views both positive and negative greatly welcomed.
    cheers
    Kru
  2. Darren Batty
    Darren Batty
    Aug 19, 2004
    135
    +3
    Kru,
    Still no replies ??, looks like your having just as much luck as I am trying to find a reveiw on the JVC THSW9
    If you take the plung on either system let me know ........ my purchase is a couple of moths off yet so I'm going to hold out for a reveiw of either system before I buy
  3. bobbypunk
    bobbypunk
    It works to a degree but there are two problems with the system you are planning. You're screen is much better than the player you are planning and the quality of surround on the pioneer isn't really to the same scale as the picture the Plasma will show. I would consider the Kef Kit100 @ £1200 as it is a good DVD player much closer to the standard and the surround is pretty good considering! (Also you don't have to worry about a centre speaker!)
  4. krupatel
    krupatel
    May 29, 2004
    64
    Thanks for the info. KEF is out of my league, although I do see your point about standards....
    Am now considering the JVC TH-SW9, like Darren, as this has progressive scan and wireless rears (yes I know wireless rears are not as good as wired and can be intrupted by furniture/people etc).
    Reviews would be helpful for this system please!
    Kru
