Pioneer DBR-TF100GB - odd colours with S-video output
Discussion in 'Satellite TV, Sky TV & FreeSat' started by alanfcross, Mar 16, 2005.
  1. alanfcross
    alanfcross
    Just bought a refurb Pioneer DBR-TF100GB from RS - they tried to sell it to me as a new one till I spotted the stickers!
    Works fine with RGB out and composite from the TVout socket, but S-video shows limited and strange colouring. The image is mostly grey with odd bits of colour here and there, mostly in areas of high saturation. I've checked the S-video input on my plasma with another source (different cable, requires S-V to S-V), and it's fine.
    I've buzzed out the cable (Nikkai SCART/S-V with a bi-directional switch) and it's fine with the switch in the right position.
    If I had got no colour at all, I would suspect that there was something wrong with S-V/composite selection in the menu, or with the choice of chrominance pin in the SCART. But because I get 'bad colour' I suspect that the wiring is right and that the problem is with the FV box.
    Anyone seen this? Is it me?
  2. Boy Lex
    Boy Lex
    Not familiar with the exact equipment, but it's possible that the s-video is sharing the same outputs as the rgb. In this case it is necessary to switch output from RGB to s-video. There may be a menu to switch between the two.
  3. alanfcross
    alanfcross
    Yes, I've done that. The options are RGB, composite and S-video. It's going back to RS tomorrow!
  4. Boy Lex
    Boy Lex
    Sounds like it's faulty then. Only other thing I can think of is looking for an NTSC/PAL switch/menu. Normally NTSC to a PAL tv gives a hazy B&W picture - sometimes you get bits of pink too.
