Pioneer cu-av200 codes
Discussion in 'Home Cinema Control & Remote Controls' started by Pegasus, Mar 10, 2003.
  1. Pegasus
    Pegasus
    I have acquired one of these from a friend but he has lost the manual can anyone help with codes for this remote ??:rolleyes:
  2. mcpru2004
    mcpru2004
    Can any one help? :lease:
  3. HighSchoolPrank
    HighSchoolPrank
    Hey
    I am sorry to say there are no codes like the newer universal remotes. you have to teach the remote how to do stuff. hold the remote to the front of the other remote*the one you want to universise* and hit a btm. the letyle switcher thing has to be on learn.
    tell me if this helps
  4. curpin
    curpin
    May 24, 2014
    I have the manual if that helps... I also need help fixing my remote, if you got any ideas, or at least where I can buy a cheap one?
