Pioneer cables - help please
Discussion in 'Plasma TVs' started by Sharonkelly, Dec 4, 2004.
  1. Sharonkelly
    Sharonkelly
    We have buried our Pioneer PDP434HDE cables in the wall but now we are moving house! Pioneer have quoted me £500 for new cables. Does anyone have any other sources/ideas. I know I can buy a 10m version of the signal cable - is this as good quality as the 3m that comes with the screen? What about the power lead? All help very gratefully received.
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    unbeatable have the 10m cables for about £200
  3. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Or you could try Joe at The Media Factory he does them for about £190 and might even have them in stock too.
    You can get alternatives from people like Wireworld...you need to buy both a DVI lead and an MDR control cable...it does not work out any cheaper but they could be of a higher quality. Try HiFi Cables
    As for the power lead you should be okay with any kettle type lead but you could get one from Russ Andrews if you wanted something that bit better.
    Cheers, Lee
