C
chrishow
Ive finally been able to locate a retailer with the Pioneer PDP 434 in stock and therefore my Fujitsu P42HHA30ES is to be replaced.
The problem I now face is locating the PDA-H03 10m cable, as my Plasma is mounted on the wall, and the cable travels trough the wall to my AV cupboard, the 3m supplied cable isnt sufficient.
Ive been told this is out of stock and wont be available until April! Do any dealers have any available here, or recommend where I can try?
Regards, Chris
Regards, Chris
