Question Pioneer BDR-209EBK Firmware Update thru SATA to USB Adapter
Discussion in 'Computer Peripherals & Consumables' started by contagious, Jun 5, 2018.
  1. contagious
    contagious
    Oct 30, 2011
    5
    I connected my Pioneer BDR-209EBK to my PC using a SATA to USB 3.0 adapter. It seems to be working fine. But I cannot update the firmware or use the utility provided by Pioneer. It says 'Target not found'. I guess it can't see the drive through the adapter. My computer is a mini PC so it doesn't have SATA ports. Is there a work around for this? Does anyone have any suggestions? Thanks.
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,668
    Norfolk
    +2,477
  3. contagious
    contagious
    Oct 30, 2011
    5
    Thanks. I could do this as a last resort. There is a mSATA port occupied with a non system disc which I could remove for performing the firmware update. But I need to purchase the adaptor and figure out a way to power the optical drive.
    Actually I was hoping for a software tweak that doesn't cost any money:)
