Question Pioneer BDP-51fd to Sony BDP-S7200 upgrade?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Stone28, Jun 27, 2015.
  1. Stone28
    Stone28
    Jan 22, 2008
    110
    London
    Hi all,
    I have a Pioneer BDP-51fd, which I have used probably 10 times ;-) - the reason - disk loading times. Wife can't be bothered because of that and I mostly use streaming services.
    Anyway, I want to change the player to something qicker but nothing fancy as I'm on my Pioneer KRP-500A + SC-LX82 so 4k is not on my radar at the moment. Is Sony BDP-S7200 (I can see it's well reieved) in this case considered as an upgrade? It's years newer so I would think tehnology moved on since then and the quality is much better even in such a cheap player. I don't want to buy anything expensive as by the time I will be changing the rest of my set up, the player which I buy now, will need to be upgraded one way on the other.
    It will be mainly to play my CDs and DVD for my daughter. Blu-Ray now and then.
    Thanks for any help in advance.
    Radek
  2. Stone28
    Stone28
    Jan 22, 2008
    110
    London
    No answer to the original question but maybe this time there will be something.
    After reading a little bit more about it I found out that the Sony is not really that good for playing music (CD's) as it's not displaying track numbers on it's display. I presume you need your TV to be switched on which is pointless. I don't want my Energy hungry TV to bo on just to listen to music.
    So what else is there which is 5* picture but also can work as a CD player?
    Thanks.
    Radek
  3. ashenfie
    ashenfie
    Jul 31, 2008
    1,961
    116
    Northampton
    +591
    well, i have a sony and am not overly impressed as have issues playing amazon prime.
    Well nearly all modern BluRay players have 5* picture quality. So it's more a game of features and CD performance.
    CD performance should also be good via HDMI as your amp i believe uses Burr-Brown analogue to digital converters. So again no need for expensive Analog outputs on your bluray player.
    That leaves features and build quality to consider. A good option is the panny dmp-bdt460.
  4. Stone28
    Stone28
    Jan 22, 2008
    110
    London
    Would DMP-BDT460 be better option than DMP-BDT-370? 370 is a newer model right?
  5. skk3
    skk3
    Sep 16, 2005
    2,544
    Rushden, Northamptonshire
    +249
    Yes, and a full sized player that I personally prefer... Review in this month's What HiFi but only for the purposes of basic information...
