Pioneer BDP-51FD or Denon DVD2500-BT?
Discussion in 'Blu-ray & DVD Players & Recorders' started by mb3195, Feb 5, 2009.
  1. mb3195
    mb3195
    Dec 27, 2007
    1,863
    2
    116
    Peterborough
    +1,813
    Hi all,
    I've currently got a Sony BDP-S550 and am running it through a Panasonic PTAE3000 on a 100" screen but am slightly put off my motion blur on certain BR discs.
    I'm looking at upgrading to either the new Pio BDP-51FD or spending a bit extra and going for the Denon.
    Firstly, will I notice an improvement with either of the players over the Sony?
    And secondly, is it worth worth spending an extra £250 going for the Denon over the Pio?
    All opinions are appreciated!:smashin:
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    what you may be seeing here is the slow speed of film at 24fps. This will be the same for all films. How do you get on with video material, better?
  3. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Hi mb3195. :)
    If you like the look/build quality of the Denon and of course you can afford it,then yes it is worth it :smashin: up to you of course mate.Some feedback here might be of use.
    All the best.
  4. mb3195
    mb3195
    Dec 27, 2007
    1,863
    2
    116
    Peterborough
    +1,813
    Watching Sky HD I dont seem to have a problem and even certain BR, such as Iron Man is superb, but from what I have been reading the Denon seems to handle movement very well.
