Pioneer ax5i receiver - help needed !
Discussion in 'AV Receivers & Amplifiers' started by Florey, Aug 16, 2004.
Tags:
  1. Florey
    Florey
    I've just bought and installed a new Pioneer AX5i-S receiver. The problem that I am experiencing is that the subwoofer does not work when I play a normal CD but works when I play a DVD ... Why ? What do I need to change to make it work ? :lease:
    The subwoofer is a M&K 1250THX
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I will trasnfer this to the amplifier forum where you are more likely to get an accurate answer. My guess is that it is a setup problem and that direct mode (or whatever it is called) uses the main pair of speakers only and not the subwoofer.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Which mode are you listening to CDs in? If you listen to CDs in 'Direct' mode then it will only send the sound to the fronts. Also If you set the fronts to large then in stereo mode it won't use the subwoofer either.
