Hi ye all good people
I have just had my 1st Home cinema system installed. It consists of a Pioneer AX5i amp with Keff 5005 speakers in a 5.1 setup.
As some here in the forums, I have my back speakers on the rear wall just above the seating position.
I have the speakers connected correctly at the back of the Amp (FR, FL, C, RR, RL) No Surround speakers SR or SL
Before running the MACC setup, the amp OSD showed the connections of the speakers as they are above
After the running the MACC setup using the supplied mic and placing it in my seating position - just under the rear speakers - The Amp OSD now shows my speakers as (FR, FL, C, SR, SL)
Now, here are my questions:
1 - Why did this happen? Is it because of the placement of the speakes relative to the Mic.
2- Does the MACC setup overrides the actual connection on the back of the amp?
3-Shall I just leave it as it is, or shall I override the MACC setup and tell the Amp that I have no surround but BR & BL?
Any advice will be gratefully received.
Thank you
Emad
Thank you
Emad
