Pioneer AX5i - Help With Movie Modes
Discussion in 'AV Receivers & Amplifiers' started by astirling, Oct 8, 2004.
Tags:
  1. astirling
    astirling
    Oct 1, 2004
    1,883
    113
    Dunfermline
    +648
    What's the difference between selecting THX cinema and Dolby Prologic II modes? The manual isn't particularly clear and seems to lean towards the Prologic II setting.
  2. recruit
    recruit
    Basically THX is a set of standards that are used in home cinema where as Prologic II is actually a decodeing format that creates the 5.1 sound out of a 2 channel signal, if i remember rightly you must select a decode format either prologic , prologic II or DTS neo 6 that THX will use on the receiver.
    Here is a link to THX
    www.thx.com/mod/products/homeTheatre.html
    It explains what THX actually does for Home cinema.
    I hope this helps alittle
    John :)
  3. astirling
    astirling
    Oct 1, 2004
    1,883
    113
    Dunfermline
    +648
    Thanks for that. But when watching a film I can select a number of modes which include (as you say) prologic II, prologic etc. etc. If I select any of them, when watching a film Dolby Digital or DTS will replace them on the display - I assume this is because that it is no longer necessary to use prologic II etc. with a 5.1 channel digital source.
    However, there is still an option to select THX cinema and I'm a bit confused about what this does.
  4. recruit
    recruit
    Yes DD or DTS is automatically selected because of the bitstream being fed to your receiver and therefore decodes that, but THX Cinema can be applied to that signal aswell, what it does is basically apply:-
    Re Equalisation - The tonal balance of a film soundtrack.
    Timbre Matching - it ensures seamless panning between the front and surround speakers.
    Adaptive Decorrelation - It changes the time & phase relationship of the surround channels which expands the listening position of the rear speakers to give a better surround experience
    John :)
  5. astirling
    astirling
    Oct 1, 2004
    1,883
    113
    Dunfermline
    +648
    Thanks!!
