PIONEER AX5AVi-S - Auto-pro set-up
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Sep 23, 2005.
Tags:
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    Has anyone used the AUTO-PRO set-up on the Pioneer AX5AVi-S?
    Does it give you a better sound performance than just the NORMAL and EXPERT auto-calibration set-ups?
    Thanks!
  2. MyBoxLife
    MyBoxLife
    Jun 15, 2005
    2,576
    Birmingham
    +126
    Isn't that a manual option instead of letting the Amp. do it.
  3. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    No. I think you still need the MCACC microphone set-up
  4. MyBoxLife
    MyBoxLife
    Jun 15, 2005
    2,576
    Birmingham
    +126
    Interested to also find out now.
  5. Geordie Bry
    Geordie Bry
    Jun 27, 2004
    1,024
    +59
    iv used it on my pioneer AX10AiS i would say it is worth doing sounds cleaner and smoother
  6. russraff
    russraff
    Aug 1, 2000
    2,329
    Newcastle
    +56
    Never even knew you could do the Mcacc with different levels of complexity!
  7. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    How did you do it? How did you set-it-up?
    Thanks.
