Pioneer AX5Ai - How do I get Dolby Digital and DTS through I-link?
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Nov 22, 2004.
Tags:
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    How do I get Dolby Digital and DTS through the Pioneer AX5Ai's I-link input from my Pioneer 868?
    Thanks, M.J.
  2. HELP101
    HELP101
    Jan 15, 2004
    285
    46
    LEIGH ENGLAND
    +112
    Go to dvd home menu and go to the initial settings and go to the i link set up put on auto put the amp on and it will detect it and set up :thumbsup:
  3. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Thanks! And then, do I just select the Dolby Digital or DTS option on the DVD disc menu itself and it will automatically output the Dolby Digital or DTS sound through my speaker set-up?
    Is the I-Link the BEST sound from this combo? Thanks again. :thumbsup:
  4. HELP101
    HELP101
    Jan 15, 2004
    285
    46
    LEIGH ENGLAND
    +112
    yes it will ok
  5. MikeFish
    MikeFish
    MJeeves
    Your amp uses the I-link input as a purely audio function by default. What you should do is go to your amplifier menu and select "function assign" (or something like that, I have a bad memory). Under that menu you will have an I-link option. Select that and scroll trough the options until you see dvd/ld and press enter.
    This way will also free up your optical input associated with dvd/ld for some other source. If you don't do this you will hear the sound with no picutres (unless the press vid sel repeatedly).
  6. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Just be aware that if the 868 is anything like the 757 in set up, that you'll need to tell the 868 to output via multichannel outputs, even though you're only using the single i-link.
  7. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    So, in essence, I need to pretend that I'm using the six multichannel outputs. What do i do re speaker set-up for those?
  8. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Precisely, but don't worry about setting speaker distances/levels etc in the 868, they'll all be bypassed and leave the AX5i to do it's thing.
  9. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Thanks buddy :thumbsup:
