Pioneer ax3 and 7.1
Discussion in 'AV Receivers & Amplifiers' started by nonikandola, Dec 16, 2004.
Tags:
  1. nonikandola
    nonikandola
    I have just got a set of Mordaunt short Speakers
    FRONT 908
    REAR 903s
    CENTRE 905c
    SUB 309
    I was wondering should i get another set of the bipole 903s and have 7.1
    What benifits will i gain from this set up or should i stick to 5.1 or get another centre speaker and go for 6.1
    cheers
  2. nonikandola
    nonikandola
    wHY NO REPLYS
  3. Docta teef
    Docta teef
    Nov 21, 2003
    1,257
    Manchester
    +56
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,517
    London
    +1,005
    If you’re going for 6.1 you may as well go the full-hog for 7.1. Depends how much space you have really.
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,942
    2
    +3,309
    I would suggest using MS302's for speakers 6&7 as using multiple bi/dipoles on the rear can lead to a messy sound field- the driver in the 302 is identical to the 903 so the sonic match will be spot on.
  6. oconnpad
    oconnpad
    Nov 29, 2004
    260
    +4
    Top tip from Tons there thanks.
    Since the 902's and 903's are the same price, if i was buying a 7.1 and going for them i'd rather buy 2 pairs of the 903's and put 1 pair at the rear. That buying judgement wouldn't have been based on anything other than same price.
    Thanks Tons
